zzp catted dn pipe??
Old Jul 4, 2017 | 06:47 PM
gds1998's Avatar
what kind of power difference with a can one expect from a zzp catted dn pipe on a 09 hhr ss? the car is stock otherwise. zzp doesn't claim any power numbers.
Old Jul 4, 2017 | 07:24 PM
Don't have any info on that, but Dave(2005HHRauto) has done a lot of testing with different DP configurations. Here's his thread https://www.chevyhhr.net/forums/hhr-...t-power-43170/
Old Jul 5, 2017 | 07:04 PM
Ohiocruiser's Avatar
If you are doing it as a stand alone mode, i doubt you will feel any power difference. I think it is more of a supporting mode, if you are getting tuned or going bigger turbo.
Old Jul 14, 2017 | 10:07 PM
RFT's Avatar
RFT
None - the stock tune in the SS has a learn down feature. You would need to go to some aftermarket tune to defeat that feature. Even GM's own upgrade defeats it.
Old Jul 15, 2017 | 11:20 AM
Jared Burton's Avatar
You probably won't see much unless you do some major mods that increase exhaust flow.
Otherwise I would assume you would lose some low end power and gain a little top end if it's even noticeable.
Mercury
2.0L Performance Tech
31
Apr 9, 2016 03:49 AM
