Cgs Intake Installation
Old May 23, 2007 | 08:38 PM
captain howdy's Avatar
Originally Posted by solman98
This type of intake allows the motore to "breath" a little better. Mileage will not change with normal driving (usually a little less at first due to heavy foot). Usually good for a couple of ponies (anything over 10 is probably a lie IMO, actual test on a V8 average 9) Intake noise will be higher.
I've ran these type of intakes on a couple of vehicles and they will get you a slight SOTP feel. Noise is the big factor for most. I don't care for the CSG cause of the filter location and the lack of heat shield. But they do work.
Others will argue, but I like the composite tubing and the heat shield. The design also sealed against the hood. Only the fender side was really open and that is where fresh air entered. It also kept the filter cleaner compared to it being totally exposed. I ran that type on a 94 delSol DOHC VTEC and has to clean the filter at least once a year.
But, you mileage may vary......
I completely agree. Other than about the CGS working that is.
Old May 24, 2007 | 11:05 AM
Lee3333's Avatar
Originally Posted by courthousedeb
I didn't have a vice to bend it with, so I pulled out my boyfriends hydraulic jack and put the arm in between the metal pieces and carefully bent it where I had marked it. Crude...yes, but effective.
Deb-no vice? When I was a teen I put a vice on my desk in my bedroom (lived in an apartment house). Same desk I did my homework on. I just drilled holes and mounted it on the end. Every good mechanic need a good vice
Old May 24, 2007 | 09:16 PM
courthousedeb's Avatar
The only vise I have now is smoking...wait a minute...that's vice, isn't it?
I really don't have a whole lot of use for one, so I just improvised. Worked great and gave my boyfriend a chuckle when I told him what I was going to do to bend the support bar.
Lee3333
"How To" Tutorial Library
7
May 20, 2019 10:27 PM
t11spanner
Oct 1, 2009 06:53 PM
thehizzle06
May 19, 2007 11:34 AM
JOEK86
Oct 14, 2006 06:52 PM
Lee3333
Apr 23, 2006 03:25 PM
