Chip
Oh boy, here we go again.
You answered your own question !! Others will probably say the same thing.
There is a number of threads on this topic if you do a search.
I've tried one of those trick the IAF/MAF sensor to think it has colder air and my mpg dropped from 33 mpg to 27 mpg, well at least I tried it and can pass along the results, it failed to live up to the claims of the company that sold it.
The only reason to fool the ECU/PCM is if it fights lower afr and your computer is the type that can't be programmed. I seen this issue for the 2000 3g eclipse, but even fooling it works only for so long.
Save yourself some cash and get a OBD-II cable and software. It is a lot of fun messing with your car's tune yourself.
I have an 07 2.2L LT1 with a Jett Performance Chip stage 2. I can tell you that my car does feel like it has more power and will peak very high in the RPMs before it will shift. I have raced my car and abused it as well. I have done over 65mph in L with the transmission. Yes the mileage did go down on the DIC and the other side is I now have to run 91 Octane and above. I have been dynoed and have 143HP going to the wheels.
Mods: Jet 2 Performance Chip
Jet MAF sensor
Cold Air Intake / KN Filter
I did not notice much change when I swapped the MAF sensor out. FYI
Jet MAF sensor
cperez1217
2.2L Performance Tech
14
Jan 8, 2008 04:45 PM
