Cold air intake HELP!
Old Mar 20, 2012 | 10:03 PM
THE BATMAN's Avatar
From my expieriences with the SS , If your not tuning for performance gaines , The computer says F-U and will show , Or produce a problem. Some have more forgiving computers , Most do not .
so it becomes a stay stock, Or get tuned thing.
I'm still stock with a drive train warranteed new engine.
It's about funds ,
Got em ,
Go nuts ,
Don't , Then enjoy what you have untill the 100,000 or 5 years are up.
Then all bets are off !
Old Mar 22, 2012 | 04:51 PM
capp002's Avatar
X2 WELL SAID BATMAN
Old Mar 23, 2012 | 05:02 PM
bassbase's Avatar
Did you use the proper 2.5" insert in the Spectre MAF tube? I have never had a problem with mine
Old Mar 24, 2012 | 09:51 PM
voigts's Avatar
I just used a piece of 2.5" pipe with a GM MAF sensor mount for mine and it works like a charm. I then got the Scoche 2.5" to 3" adapter to run the 3" pipe down behind the headlight.
Old Mar 24, 2012 | 10:04 PM
HHRNole's Avatar
Sounds like mine,great intake for not much moneyName:  001-16.jpg
Old Mar 27, 2012 | 07:41 AM
  #26
roguewave's Avatar
Just wondering how that works in high water? Hydraulicing (sp?) a motor can be real expensive...
Old Mar 27, 2012 | 09:05 PM
  #27
HHRNole's Avatar
No problem,the filter is up behind the headlight. The filter would have to be submerged to hydro lock the motor.Been running with this set up for awhile now and thru several heavy rain storms,worked just fine.
Old Apr 5, 2012 | 01:03 PM
  #28
JWOO's Avatar
this is pretty simple and gets the job done... I done this in the past with hondas i owned.
Old Apr 16, 2012 | 07:15 PM
  #29
The Thing's Avatar
I got it to work thanks for the pictures it looks great. I had to cut off the stock MAF tube off the stock box as wheel. Im thinging of putting a hood scoop on with a big CAI filter running to it.
Old May 10, 2014 | 05:50 PM
  #30
Britjoe's Avatar
Heres my attempt, it through a code at first, I cleared it and it runs great, lots of induction noise that I actually like, the code it through was a bank one code running lean. ill see how it runs and I haven't altered any of the OEM stuff so I can go back if i want to.
