New Header for my HHR Panel
The 3 studs that came with the header are the wrong size, need to drop everything and drive over to the muffler shop to get the correct studs for this header.
Also need to get a plug to block the hole used normally for the senser on cobalts, the rest of this header seems to be ok.
Information for other members that want to install the same header
Yes, I checked out your link, yes it's the same, thanks for the info, it's finally installed.
I will post an update in a week, this way I will have a better idea on gas millege and performance.
Once the original exhaust manifold was removed and compared against the new one, WOW !, what a difference.
The new manifold has a major improuvement on the exhaust flow, I have not yet seen a change on HP, but the gas millege is better.
This is my first mod which I recommend to every one, the sound has not changed.
The next mod 18" mags from the HHR SS, probably will lower the vehicle as an SS.
What mileage gains have you been able to verify? I pt a complete 2.4 exhaust system with single larger cat and a Cherry Bomb Vortex muffler. It really breathes and sounds better but the mileage improvement was minimal.
I certainly would put a header on there if it was to give any decent verifiable gains in mileage.
