Nitrous bottle on a HHR?
Old Jul 22, 2007 | 07:36 PM
en0oNmAI's Avatar
whether you use it much or not your rev limit comes on FAST and nothing in your kit will save you from a blown engine. Activating TOO low can cause an explosion inside your intake manifold and happens a LOT with the ecotec motors. Hitting your rev limit too many times will blow the top end clean off. Even a 2nd gear pull with nitrous makes the 6500 come up VERY fast!!! Just a warning. My advice? play it safe and get a MSD Window Switch.
Old Jul 22, 2007 | 07:39 PM
doughboy's Avatar
where would i get that switch?
Old Jul 22, 2007 | 08:41 PM
RUDEINC's Avatar
RUDEINC's setup:
REVISED EDITION....LOL
Old Jul 22, 2007 | 10:34 PM
en0oNmAI's Avatar
From MSD. Check their website.
Old Jul 23, 2007 | 06:40 AM
Black Beauty's Avatar
From my understanding, the NOS set-up is designed to kick in at 'Full Throttle', how often do you expect to have an opportunity to be at full throttle, unless you`re on a drag strip or street racing?
A supercharger/turbo is much more street friendly, and give you a reasonable expectation that you can use it in day-to-day driving... Plus you don`t have to recharge.
Old Jul 23, 2007 | 11:02 AM
en0oNmAI's Avatar
but nitrous is WAY chaper than a turbo..
Old Jul 23, 2007 | 02:40 PM
What`s the little filter on the valve cover???
Old Jul 23, 2007 | 02:53 PM
doughboy's Avatar
yea see i like the good gas mileage i have now, and i only want a kick when i want it not a constant waste of gas! plus like he said it is way way cheaper! plus if i ever have a problem i can take the nitrous out for warranty work! also enoonmai how are your tail lights working with that paint on the i checked out your club site???
Old Jul 23, 2007 | 03:03 PM
I have a Turbo, with boost gauge, you can monitor you engine/vacuum, and anytime you`re in a negative boost, you`re running efficiently, actually using wasted exhaust gas to power engine. And BOOST on demand, no buttons to push.
I don`t think I`ve ever even had my Turbo at wide-open-throttle, (while driving), and I know I`ve never done so in the HHR.
Old Jul 23, 2007 | 03:09 PM
doughboy's Avatar
is your hhr turbo??
