Removing 2 Cat??
Old Aug 13, 2012 | 10:13 AM
SpaceCowboy's Avatar
sure it won't mess up back pressure or affect performance?
Old Aug 13, 2012 | 10:39 AM
swerv0428's Avatar
Thats what im asking. The guys at the shop say its fine. But im asking if anyone knows of any issues with removing it
Old Aug 13, 2012 | 10:53 AM
well how far is it away from the nearest O2 sensor?...guys are muffler techs of course they will say its fine
Old Aug 13, 2012 | 11:02 AM
swerv0428's Avatar
I'm not under the car right now. But the second cat is behind the o2 sensor like one foot or so.
Old Aug 13, 2012 | 11:17 AM
solman98's Avatar
It's a small high flow cat. The differance in sound probably won't be much. But it is a $10,000 fine for removing a cat and not replacing it. Your state not having emissions testing has nothing to do with it.
Do it right, or don't do it at all.
Old Aug 13, 2012 | 11:18 AM
chefhhr's Avatar
I wouldn't do it personally. If you want more sound, pick up a cheap aftermarket muffler and have them weld it on. You can check with Thrush or Dynomax...both of which are pretty cheap and will give you added sound. I'm adding a Dynomax to mine.
Old Aug 13, 2012 | 11:36 AM
prince_bigd's Avatar
It actually depends on your state and the location of the cat. Ths being a secondary it shouldn't cause any violation issues. Look at how many lnf guys are running catless dp. Id say try it keep the cat or even better pick up a high flow metal core cat and if you don't like it simply put one back on. I ran a 300 cell metal core vibrant on my vibe which was a 1.8 1zz Toyota motor and it made a larger difference than just the rest of the exhaust put together.
Old Aug 13, 2012 | 12:18 PM
swerv0428's Avatar
Im at the shop now. Im getting it removed. If it dont work out ill put it back on. Trial and error.
Old Aug 13, 2012 | 01:18 PM
swerv0428's Avatar
Ok the second cat is gone. After about ten miles around town it is awesome. At a steady speed or at an idle there is no noticeable noise. Under light acceleration you can here the exhaust. Under heavy throttle all I can here is the intake.
I'll post a sound clip in a little while. I think it sounds awesome. I had the resonator removed and it sounds about like I removed another resonator. I like the pop and Gargle under deceleration.
Old Aug 13, 2012 | 01:21 PM
solman98's Avatar
This is a federal law. catless dp is also illegial. Those are sold for non public road use only. I'm sure the users know that.....
Under federal law, catalytic converters may not be removed
and replaced with "converter replacement pipes' by any person.
The 1990 Clean Air Act Amendments even prohibit private
individuals from installing "converter replacement pipes" on their
own vehicles. Anyone who installs such pipes would violate section
203(a)(3)(A) and (B) of the Clean Air Act (Act).
