Turbo on a 2.2 HHR
Old Sep 13, 2010 | 09:15 AM
masterchief1112's Avatar
when you get injectors make sure to get the connectors for the injectors as well. zzperformance is a good source. hop on cobaltss.net there is a lot of useful info over there
Old Sep 13, 2010 | 06:50 PM
hhr_2009's Avatar
Thanks for the info, I will get in touch with vince to see what is best for this setup
Old Sep 13, 2010 | 06:51 PM
hhr_2009's Avatar
Great, I found some 42# injectors that Vince recommended on the cobalt forum, but not sure if they had connectors included.
I just saw 4 injectors.
Old Sep 14, 2010 | 06:26 AM
they will most likely use a standard bosch injector, should not be able to find them. when installing rather than cutting up your wiring harness you can transfer the pins from your old connectors to the new ones.
Old Sep 14, 2010 | 08:14 PM
hhr_2009's Avatar
I found a set with the connectors from a cobalt, would they work on my 2.2 with out cutting any wires
Old Sep 15, 2010 | 10:59 AM
-md- HHR's Avatar
They should, but it may depend on the year.
Old Sep 15, 2010 | 02:59 PM
mrsilent13's Avatar
if you need any help doing this turbo...i have turbo'd a g5 and my own cobalt...both 2.2's...and i have also done work on the supercharged cobalts....
i have done full engine rebuilds on the ecotecs...both forged and stock internals...so like i said...if you need any help send me a pm...and i will do my best to give you the correct advice
Old Sep 16, 2010 | 02:39 AM
hhr_2009's Avatar
Would you know for the injectors from which year would be compatible with my 2009 2.2.
thanks
Old Sep 16, 2010 | 08:48 PM
TomsHHR's Avatar
bump
Old Sep 19, 2010 | 02:04 AM
mrsilent13's Avatar
well in some/most cases you would need to modify your harness to fit the new injectors
