Custom Side Exhaust Question.
Old 07-24-2017, 08:26 PM
bursjon's Avatar
Question Custom Side Exhaust Question.
Hey there everyone.
It's been a while since I have posted but I have an idea that I need some help with.
I am considering a modification to my exhaust but am not sure if it will even work.
So here goes my idea, I want to make a junction right before the rear axle and have 2 side pipes that go out to just before the rear tire, but, here is the fun part.
I want to have my stock muffler left in place so that I can still use the stock muffler as well. I have made a simple drawing that should help explain what I mean. (See attachments)
I want to put a gasket like the manual exhaust cutouts have on the side pipes so that when they are sealed all the exhaust goes through the muffler at the back being nice and quiet. but then I could very easily take off the covers on the side pipes and have a nice muffler delete with side pipes.
I am not sure how the + junction under the car would affect the exhaust flow and if the pipes when they are sealed would cause to much heat and melt my running boards and also they would be running right past the fuel and brake lines.
Any input would be greatly appreciated.
Attached Thumbnails Custom Side Exhaust Question.-z12boltexhaustgaskets-5540.jpg
bursjon is offline
Old 07-24-2017, 10:15 PM
My first thought is that you would have ground clearance issues if you run the pipes under the running boards. Maybe they can be routed through the rear wheel wells? Just a thought. Probably also a bad idea.
RJ_RS_SS_350 is offline
Old 07-25-2017, 08:08 AM
bursjon's Avatar
That is a good idea.
I will have to take some measurements and see how the ground clearance would be affected.
bursjon is offline
Old 07-25-2017, 08:17 AM
The side outlets have been done, there might still be pictures in here somewhere
https://www.chevyhhr.net/forums/sear...Dual%20exhaust
Oldblue is online now
Old 07-25-2017, 04:13 PM
bursjon's Avatar
I know that it has been done before but to my knowledge, no one has had the stock muffler and side pipes so that they can be sealed and able to run quietly with the stock muffler and with a muffler delete if one so wanted to.
bursjon is offline
Old 07-25-2017, 07:12 PM
That would be a first.
Old 07-29-2017, 08:59 AM
Casa Del Gatos's Avatar
Lots of electric cutouts out there.
Jegs has some cool options.
JEGS Electric Exhaust Cutouts | JEGS
Casa Del Gatos is offline
1Panel2NV
02-18-2012 05:17 PM
jeff schaffer
Mods - Exterior
12-27-2011 03:27 AM
RETRO-RED-EXPRESS
12
10-25-2010 11:28 PM
Kar Krazie
15
02-18-2006 04:51 PM
Quick Reply: Custom Side Exhaust Question.
