Electrically dead
Old Apr 7, 2020 | 01:50 PM
Cat Man HHR's Avatar
Lights mean nothing right now.
Can you communicate with the ECM ?
Hope you took out that wire that Bubba installed.
Old Apr 7, 2020 | 03:18 PM
Panelvanman's Avatar
The scan tool can’t verify the key is in the on position. But the obd port does have power.
Old Apr 7, 2020 | 03:23 PM
All the ecm fuses and bcm fuses are good.
Old Apr 7, 2020 | 03:28 PM
"good" as in visual inspection shows a continuity in the element, Or there is power to all of them when there is supposed to be and a electrical continuity test was done on each of them?
Old Apr 7, 2020 | 03:37 PM
I just made sure they were not blown with the ohms setting on my volt meter
Old Apr 7, 2020 | 03:39 PM
I have the phone book sized manual out now. I’m searching for when these are supposed to be powered now.
Old Apr 7, 2020 | 04:23 PM
I think it may be the bcm has died. I’m not just saying it’s computer because that’s what everyone jumps to. I have checked and voltage is going to the bcm, but none of the fuses have power going to them. I’ll try and upload pictures to explain what I mean.
Old Apr 7, 2020 | 05:15 PM
If it were the BCM, the headlights would still work. But you may have more than one issue. Did you check the maxi-fuse?
Old Apr 7, 2020 | 06:10 PM
Just making sure, by maxi-fuse you mean the one in the back by the battery? I have checked it
Old Apr 7, 2020 | 06:43 PM
Check on the negative cable the current sensor and the battery cable clamps are they cracked?
https://www.google.ca/search?q=HHR+n...&client=safari
