Electrically dead
Both batteries I’ve tried in the car are good. Both have 12.5 volts and I charged the one that came in the car overnight just to confirm it was good. I’m not getting any codes because the scanner won’t talk to the car. My scanner says the key needs to be on. Even though the key is on when I scan it.
There is no signal to the run or start relays. There is no signal to any of the relays in the underhood fuse box. I’m not getting power to those fuses either. But I do have power at the post under the red cover.
