?Group Buy on Tune Tyme?
Old Mar 15, 2007 | 12:41 PM
  #61
en0oNmAI's Avatar
Whoever told you that was uneducated Lee. The stock injectors are already at 97% duty cycle with a VERY MILD tune on them from what we saw with HPTuners. You NEVER want your duty cycle higher than LOW 80's. If you overwork your IDC then your injectors will wear out FASTER. Bumping up to the higher injectors reduces the IDC to mid 70's range and is safer and you get even MORE power from it. It also raises the rev-limit to 7000 and the power band is AMAZING! When the shift points were set THEN it really felt awesome.
We are putting a CA header and 2.5" catless downpipe on the Cobalt sometime in the next week and will re-tune and post results. Also adding a trans cooler to help with the trans temps. We're looking at a Auto SS/NA that will soon be just as fast as the SS/SC's are stock. 14's here we come!
Old Mar 15, 2007 | 01:14 PM
  #62
hvrod's Avatar
Using stainless steel lines on your Trans Cooler ?
Old Mar 15, 2007 | 01:54 PM
  #63
en0oNmAI's Avatar
Yes. Doing custom mounting brackets and such as well. Basically a twin pass design. Its 4.5" tall and as long as the radiator. The lines are high pressure lines and will replace the stock tranny lines also. We were thinking of tapping the "out" line from the stock trans cooler in the radiator and running it IN to the new cooler then OUT and back to the tranny so that way it gets twice the cooling. But, we'll see. Should be FUN!!!
Old Mar 16, 2007 | 03:19 PM
  #64
hvrod's Avatar
Okay the harness arrived.. Fedex delivered it..
Will do the injector and harness install , either afterwork or this weekend.
Now just waiting for my ECM.. back
Old Mar 17, 2007 | 01:50 PM
  #65
Bertland's Avatar
Those the sale still on!? I need my truck for school, I will put my Z on the road in midlle off April, only then I will be abble to send my ECM...
Old Mar 17, 2007 | 01:53 PM
  #66
Ya might wanna PM Matt at Tune Time aka- ludicristSS here.
Old Mar 17, 2007 | 01:57 PM
  #67
Bertland's Avatar
Thank's, I will!!
Old Mar 17, 2007 | 02:44 PM
  #68
hvrod's Avatar
You can try also Wester's Garage , which is located in Canada also..
FYI...
Pricing is different thou...
http://westersgarage.eidnet.org/GM.htm Shows. 495.00
Old Mar 21, 2007 | 02:16 PM
  #69
hvrod's Avatar
Harness and injectors installed,
Still waiting for the ECM.. its on its way...
(mail got held up, going to tuner)
Old Mar 26, 2007 | 07:46 AM
  #70
ludicristSS's Avatar
Don't put to much fath in the HPt scanner [ we have seen a lot of wrong data when compared to a snap-on solus or GM Tech 2 I.E. TPS ,INJ duty, Timing ,KR to name a few ] ...You need a w/b as well as a more reliable scanner ...BTW since when are the intake valves open 80% of the time ? Yes it's a good rule to follow but untill you making 190+ at the wheels stock injectors are fine based on our dyno testing and Tech 2 scan's
