installing after market turbo
I am new to the hhr network but I have got my hhr to the very end of the turbo setup process. I have a t3/t4 with air to air intercooler. Made my own intake maf housing. Put #80 injectors and am currently running e85 but after all this work I'm now getting p0606 codes after sending my ecm and tcm into zzp for tuning. At first it was throwing lost comm with tcm after grounding it to frame its now stuck in limp mode with p0606.
Dark but this is my spray with tractor / farm equipment paint. Satin black
Overlook the mess. Im not going to put much into looks untill i get functionality.
Get rid of the "farcebook ground"; it is dangerous and completely useless.
P0506 means that the ECM is not programmed or the connection to the throttle actuator is balky.
My first guess is that you bent or pushed a pin or 2 in the ECM connector. Maybe ZZP messed the ECM up.
Communication codes usually caused by wiring or fuses.
I wouldn’t necessarily agree. I think a HPFP would only be needed if it was a direct injection engine. Since the 2.4 is not DI like the 2.0 LNF in the SS, the regular fuel pump with upgraded injectors should work. Just have to get it tuned correctly.
The 55 to 60 psi in tank pump won’t keep up. So perhaps a higher capacity electric fuel pump
https://walbrofuelpumps.com/255lph-w...pump.html.html
Zzp
They keep putting me off until the 2week mark was over so I couldn't get it fixed. But I found were I had my ac disconnected beside it is a wire that I have no clue where it came from. I'll get pics soon as I can but would my ac be causing a PCM fault code?
This says it's an internal fault in the ECM https://www.obd-codes.com/p0606
What's the significance of this 2 week period?
Here are the 80 pound injectors on ZZP https://zzperformance.com/products/siemens-80-injectors
You have the 2.4(LE5)? On that page ZZP says you need this https://zzperformance.com/products/b...ressure-system
if you're making 12 psi or more boost.
Ecm
