Installed My G-Tech...
Originally Posted by HHR DLYT
I am sorry I forgot to include that, it was a Dynojet dyno. I was going to put that in my post because I knew it makes a difference. I wasn't sure if anyone was even interested in the before results since I do not have after results. Also the test was done in second gear according to the report.
Most all dyno runs will be in a second or third gear, this way the engine is under a strong load while the power band is traveled.
Originally Posted by monster5601
I'm interested in all results so thanks for posting. You don't by chance have the torque value, do you?
Originally Posted by snksknr94
A dyno pull should be done in a the direct drive 1:1 ratio. Anything lower and your getting a false reading due to torque multiplication through the trans.
The purpose of a dyno is to baseline performance which is useful for discovering gains/losses when tuning. It is not a good tool for comparing another same vehicle or comparing data, across days, because of environmental issues.
As long as you profile the powertrain using the same gearing on each pull, your results are fairly accurate with respect to the engine's environment (e.g.: engine temp., air temp., humidity, etc).
When doing a dyno run, you capture the engine's abilities (ability to apply torque with respect to time (HP)) begining in a mid gear all the way through to the end of the gear's range (max RPM).
If you ever get a change to watch a dyno pull, you will see what I'm talking about. Check out some of the car shows on the speed channel or spike TV.
When my tuner does a dyno pull on my GTO, they get the car 's speed up to the low end of 3rd gear and then go wide open throttle to red line. Then they make adjustments to the timing or fueling or what ever they are tweeking this day, give the engine a 20 min. cool down, and start over.
I dissagree, and this is why:
Is your GTO an auto?? Third gear is the 1:1 ratio in a 4 speed auto.
On both vehicles, a 1 to 1 ratio was in third gear for the automatics as you indicated. For the manuals, the GTO had a 1:1 in fourth gear and the HHR's manual had a 0.98 ratio in forth gear.
My GTO is a manual and third gear has a ratio of 1.43. Should my tuner be doing my dyno pulls in forth gear?
I think you are trying to teach me something here but I'm missing it....
This is interesting, when I got to work this morning I looked up both the auto and manual trannys for both the GTO and the HHR, here is what I found:
