Jet performance
Jet performance
Has anyone installed on their car I have a stage two have not installed it yet but wanted to get some feedback b4 i install. May return it
http://www.jetchip.com/products.asp?...el=95487#95487
God Bless!
Rick Johnson
God Bless!
Rick Johnson
God Bless!
Rick Johnson
God Bless!
Rick Johnson
I ran a Jet PCM on a previous GM vehicle (yes a piggy back OBDII setup like this), hope they have improved these things. All they did before of change timing and adjust air/fuel ratio. Definatley not worth what they charge for them.
Good luck
Good luck
I did the performance chip mod on my MINI Cooper S, save your money unless you do other mods first;
1) cold air intake
2) free flow exhaust
3) header and or free flow CAT (prepare for o2 codes)
4) now you do the chip...
Intake and exhaust are the best bang for the buck, most engines are strangled and need to breathe, plus they contain everything for noise and emissions.
My 3 cents (inflation)
1) cold air intake
1) cold air intake
1) cold air intake
The jet chip works great you can tell the car has better performance and it gets better gas mileage if you watch you foot below 65 mph above you get better performance and less mileage than before. The only down fall is you need to use 91/92 octane fuel I used mid grade fuel and the mileage suffers. My car has a intake and exhaust and now a BBK
God Bless!
Rick Johnson
God Bless!
Rick Johnson
Don Juan
2.2L Performance Tech
10
Mar 13, 2008 06:28 AM
