K&n cipk
K&n cipk
Okay Okay, I have read most of the forums that I can regarding K&N type cold air performance kits. They're expensive, they are more for looks it is said.
But do they work?
Like oil changes, nitrogen vs. air in the tires, etc. There must a 1000 different opinions. One person who I work with states that the oil collects and the filter clogs faster - so it is worse for the car. He is also a race car driver. But the way he treats his personal vehicles and the ambulances is horrible - so I don't put much stock in what he has to say.
Do they work? Are they worth the price? Are they snake oil?
Any info would be helpful.
Chris
But do they work?
Chris
I own a Diesel truck. On the Diesel forum there was a guy who worked at an oil testing lab. It is very common to do oil testing on Diesels since they hold so much oil people like to stretch the oil changes. This guy swears he could always tell from the test results if the oil came from a truck with a K&N filter on it. He was always right!
He could tell by amount of solid particles in the oil.
I have "performance" intakes on my sports cars but none of them have K&N filters.
napa gold
you may want to try napa gold air filter. it would be a much less expensive test. you may also want to remove or replace anything that is restricting air flow. i took the fuzzy colapsable gm cold air tube off mine and gained more than 2mpg along with adding the napa gold. maybe mine was defective , maybe not , but it was restrictive.
Really? 2mpg? Where exactly is this thing, and how do I take it off? I'd really like a little mpg gain! Every bit helps
part
part of the gain could have been the replacing of my filter. it's the thing that looks like a big wooly worm , or a fuzzy radiator hose , the cold air hose. mine is 08 , others may look different . i can't believe that k&n does not give a new smoother 1 with their kit.
Thanks!
