OEM Cold Air help!
Old May 8, 2008 | 02:07 PM
solman98's Avatar
Originally Posted by hhrcrafty
One thing I don't get is the "K&N stumble" I experienced on my Sonoma and Blazer after I installed K&N filters and the MAF sensor became coated with oil.
Been running K&N filters, both the drop in and the FIPK's for over 15 years. Never had any issues with the MAF. Maybe they were over oiled at some point (even factory).
Old May 8, 2008 | 02:13 PM
bigallis1's Avatar
Originally Posted by k5hart
I've had the K&N unit almost from the time the car has been new and never had any problems. It did make a small noticeble difference in power. 9HP...I don't know about that but I did get 35 MPG on a 8.5 hour trip this past weekend. I wonder if the stock filter would have shown the same results. All in all, I'm very happy. I did it most for looks and sound.
Same here. Identical results and observations with mine.
Old May 11, 2008 | 06:42 AM
Mohican's Avatar
The only time I have seen oil build up on the MAF sensor is when someone used those recharge kits and used too much oil after they cleaned the filter. K&N now has oil less filters which claim to be just as good as the oiled ones which is the way I would go. I have used the oiled K&N on almost everything of mine for years and never had a problem with excess oil build up on the MAF.
Old May 11, 2008 | 07:32 AM
JoeR's Avatar
Originally Posted by solman98
I disagree with the first part here. Colder air is denser and will make more power.
But I also agree that the stock intake is very good and agree with the second part.
Re: 1st part.... Solman, we are in 100% agreement on intake air temps vs power. Maybe I wasn't clear enough. Actually the HP will vary about 1% for every 10* F change in temp, hotter resulting in less HP, colder in more.
Old May 12, 2008 | 06:11 AM
solman98's Avatar
That was probaly just a long day for me......
Old May 12, 2008 | 11:12 AM
nextep1's Avatar
OK OK OK...
SO what I'm selectively hearing is that the K&N, properly or lightly oiled, will not cause an idiot light to come on and I can expect a small increase in HP and economy...Every body is generally happy with it so it's worth the 2 and a half beans...
Old May 12, 2008 | 11:21 AM
solman98's Avatar
Originally Posted by nextep1
OK OK OK...
The "recharge" oil for K&N used to come in a "squeeze" bottle. If you were not careful, you could overoil them. The last kit I picked up actually had a spray bottle to re-oil. Made doing the proper coating much easier IMO. I never had any problems the old way, but some did.
HHRatRod
Jul 10, 2008 03:03 PM
Brewmaster
Jan 21, 2008 06:12 PM
Scarecrow
Apr 6, 2007 07:15 AM
