Oil Change???
Old Nov 12, 2009 | 07:04 PM
JerryB's Avatar
Lightbulb Oil Change???
I just bought my 06 HHR. It has 33,000 miles on it. When I turn on the A/C, I can tell that there is a vibration and the engine seems to run rougher. Is this normal??? This is like one of the only 4 cylinders I've ever owned. I'm hoping this is normal...
Thanks, JB
Sorry about the mis-leading "Oil Change" heading...
Old Nov 12, 2009 | 07:25 PM
davidjb's Avatar
I believe its normal, my 08 ss does the same thing. not a bad vibration but there is a difference. my first 4 cylander also.
Old Nov 12, 2009 | 11:09 PM
Well, my 08 Panel does not vibrate, when I do turn on the A/C, the rpms' do automatically increase slightly to compensate for the additional parasitic drag, but no bad vibes.
Just my .02
Old Nov 13, 2009 | 07:25 AM
solman98's Avatar
Just my .02
Same here.
Old Nov 13, 2009 | 07:37 AM
esmarkey's Avatar
I don't know how many times we have to have this debate?! Change the oil when the DIC gets to near zero percent remaining!!
Oh, on such a small engine the extra drag of the AC compressor will be noticeable on some vehicles. Should be much at high speed, but at idle you may notice, especially if you are coming from a much larger engine. I can't even tell when I turn the on the AC on my 7.3l diesel
Old Nov 13, 2009 | 03:10 PM
Snoopy's Avatar
I have no noticeable change in engine performance/operation when I use the A/C in my '06 2lt. And I use the A/C NEARLY everyday.....living in Arizona.
Car is parked in a garage....a/c is turned off. When I start it the next day, I drive maybe 1/4 mile then tirn on the a/c. Don't notice a thing. Course I'm an ol' guy, and miss a lot of things.
Old Nov 13, 2009 | 10:17 PM
Hotrodbob's Avatar
Rarely turn the a/c off. Don't notice any difference on or off.
Old Nov 14, 2009 | 08:52 AM
VictorySpark08's Avatar
My 08 Sounds a little rough when the A/C is on, As stated Change the Oil according to the DIC, I usually Change mine around 30% the Every 3k is nothing more then a Marketing tool used for year's.
solman98
Maintenance and Upkeep
255
Aug 8, 2014 07:39 AM
JWA
16
Jun 21, 2014 12:16 PM
badassbowtie
23
May 12, 2013 02:01 PM
SIHHR
Feb 14, 2007 07:35 PM
