starter or alternator?? helllpppp
Old Apr 22, 2015 | 09:45 PM
sandyyyy's Avatar
I have a 2006 hhr. I was driving on the freeway and it just completely shut off. Tried restarting it and nothing you can just hear it clicking. I was told the alternator then they changed it to the starter. The battery was checked and charged at autozone. (Good battery) any info is greatly appreciated! Thank you.
Old Apr 22, 2015 | 10:03 PM
If it shut down while driving, then it's not going to be the starter. Most likely the voltage dropped ( maybe from a bad alternator ) and that is what shut off the car.
Your going to need someone to do some hands on diagnostics to pinpoint the cause. Any internet guess will just be a guess of many possibilities.
So. After the battery was charged by AZ, did you try and start the car ? With a fully charged battery, it should have at least turned over or maybe even started.
Old Apr 22, 2015 | 10:05 PM
sandyyyy's Avatar
Yes tried it again and same thing...still did the same thing which was just the clicking sound.
Old Apr 22, 2015 | 11:06 PM
black Tara's Avatar
I still think it might be the battery
Old Apr 23, 2015 | 05:15 AM
prod's Avatar
Sounds like it could be a case of the fuse box separating, its happened to others. I think pushing the two sections together solved it, try a forum search.
Old Apr 23, 2015 | 06:04 AM
OR, the red wire connecting to the fuse box.
Old Apr 23, 2015 | 06:28 AM
LawDog88's Avatar
Check the box retention under the hood. Make sure it's seated well, and all the fuses are tight.
The clicking makes it seem like a battery. How old is the battery you have? Original to the car?
Old Apr 23, 2015 | 08:28 AM
And double check the ground wires at the transmission just down to the right of the oil filter housing while you are looking check the ground wire at the rad cradle just behind the hood bumper on the driver's side in the engine bay.
Old Apr 23, 2015 | 03:33 PM
Hey sandyyyy,
Welcome to the forum! You've already received some great info from the community here, but if you'd like to bring this to your local Chevrolet dealership's attention, we'd be happy to contact them on your behalf. Send us a PM with your VIN, mileage, preferred dealership, and contact information if you'd like us to go through with that.
Let us know if you have any other questions as well. We're here to assist.
Geoff G.
Chevrolet Customer Care
2005HHRauto
2.0L Performance Tech
Jul 3, 2016 10:44 AM
bduemig
Oct 26, 2013 09:13 AM
lesserdawn
May 24, 2013 06:13 PM
Copperhead
Oct 27, 2007 10:53 AM
betterof2evils4
Sep 26, 2007 10:22 AM
