For those who put on a header/manifold...
Old Mar 9, 2007 | 07:21 PM
en0oNmAI's Avatar
You could make a kind of spacer to go between them to keep the hose off the header. Something like a piece of rubber (exhaust mount type) with a couple metal washers on each end to keep thr rubber from melting. Might help. Like a rubber sandwich with washer bread.
Old Mar 14, 2007 | 04:36 PM
hvrod's Avatar
Originally Posted by Applenut
I bought the Cobalt Addiction Header, because I knew you made it work, but there is a problem. My mechanic bolted it up jut fine...then noticed that there was a leak from the coolant line running behind the engine. The header tube for the #4 cylinder (driver's side) touched the coolant line just enough to cause it to leak at the "o" ring. Did you have this problem, and if you did how did you overcome it, I don't want to dimple the header if I don't have to, that could make things worse.
Please let me know, thanks.
Cobalt Addiction , mention they were to make adjustments for the header.. I hope you mention to him you were getting it for the HHR..
Anyways.. the large coolant pipe/line that runs on the back of the engine, needs to be adjusted for your header doesn't press on it when you bolt it to the engine..
So the 3-4 bolts on each side/end of the large coolant pipe need to be loosen.. once loosen, slighty put the header back into position, and feel along where it it touching the coolant pipe.. rotate the coolant pipe so the header clears the coolant line..
Once that is done.. retighten the coolant line bolts you loosen, and finish the install of the header..
I've had no problems since...
Old Mar 17, 2007 | 01:56 PM
Bertland's Avatar
Can you show pics of your installation!?
Old Mar 18, 2007 | 09:17 AM
hvrod's Avatar
They somehow got misplaced or deleted by accident.. I was only able to find one..
dbent
2.2L Performance Tech
29
May 25, 2013 11:09 AM
dbent
Nov 10, 2009 04:31 AM
GDZHHR
2.4L Performance Tech
20
Feb 25, 2009 09:20 PM
HHRDK
May 6, 2008 07:45 PM
