Why did GM lower the horsepower ratings?
Old Nov 28, 2007 | 05:08 PM
mynameistaken's Avatar
2007 2.4 175 hp and 165 lb-ft of torque
2008 2.4 172 hp and 162 lb-ft of torque
Its only 3 hp but what did they change?
Old Nov 28, 2007 | 05:10 PM
Maybe conditions at time of each testing, such as temperature, were a bit different.
Or maybe they just had a bunch of super squirrels to put in the 07s.
Old Nov 28, 2007 | 05:31 PM
calgaryhhr's Avatar
Aren't the 2008 numbers the same as the 2006 numbers??
I think 2007 was just an anamolous year.
Old Nov 28, 2007 | 06:12 PM
JoeR's Avatar
The newer GM ratings are SAE Certified, same procedures, but need to have a SAE certified technician there. No changes in the engine, so the difference is well within the norm....
IOW, no big deal ---------- No changes.
Old Nov 28, 2007 | 07:23 PM
photojoed80's Avatar
'07's are SAE certified too. I have read that the difference for '07 had something to do with the catalyst. If I can find the article, I'll post it.
Old Nov 29, 2007 | 01:42 AM
Dan's HHR's Avatar
to all 07 owners we're the meanest HHR
Old Nov 29, 2007 | 06:42 AM
solman98's Avatar
The certifications for all 2008 models are much tighter than the 2007. That is why the EPA numbers changed as well.
Old Nov 29, 2007 | 07:01 AM
Yeah, I was thinking they tightened up emissions or fuel economy a bit.
Old Nov 29, 2007 | 02:50 PM
Don Battista's Avatar
I have an 06 2.4, Same HP as the 08.
I remember reading some were that the 06 & 07 2.4 are the same Engines and were advertised wrong in regards to Horse power.
Old Nov 29, 2007 | 05:20 PM
an08HHR's Avatar
I noticed that also in the brochure and thought maybe they changed the compression ratio a little since it can use 87 octane (91 recommended but not required) and this helps along with the VVT to eliminate and chance of knocking.
