18s by 8.5 these work?
Hello everyone,
I guess 20s arent the way to go for an HHR after all the stuff I have heard about them, I think I would like a little more tire meat on the rims. So I am steping down to 18's once again. I wanted to see your input on these rims if you like them or not, and if you guys/girls have any ideas if they will stick out at all. And if I will have any problems when I lower it with the Eibachs or Goldlines. Thanks for the input.
http://americanracing.com/appguide/f.../SUV&model=HHR
Well, being a full 2-inches wider than the stock rims, I'd imagine you will need considerable modification to get them to fit without rubbing.
Also, the offset is only 35mm - not good. The stock HHR offset (with a 6.5-inch rims), is +42mm. Most wider rims (17x7 & 18x8), are available in a +45mm offset. The rim you are proposing has less offset then the stock (narrow), wheels and will stick out considerably.
Hope it helps,
Hope it helps,
Thanks Sindy! Any other Rims you would consider?
what about the ones above i mentioned?
i like them the first ones i where going to get where going to be chrome too. But these new ones look similar to the first but they at 7.5 wide not 8.5 and they have the correct offset according to Mike SOCALHHR
