3-Bar Grille Mod Completed
Old May 14, 2008 | 01:45 PM
Togma's Avatar
I'm considering doing the 3-bar on my HHR as well. I was wondering if you had a close up of where you removed the 2 bars from as well as where the vertical tabs connected the bars together? I'm curious as to what the area that you cut looks like. I don't want to start cutting before I know what it is going to look like close up, it would drive me absolutely nuts if it was a mess. Thanks in advance for any info.
Old May 15, 2008 | 07:11 PM
bigallis1's Avatar
Here's 3 close-ups of cuts. Hope this helps.
Old May 19, 2008 | 11:23 AM
Togma's Avatar
That's exactly what I was looking for. Couldn't have done it better if I had taken the pic's myself. TY so much.
Old May 19, 2008 | 09:10 PM
Goose's Avatar
Wow! Looks awesome! I'm jealous
Goose
Old May 20, 2008 | 10:25 AM
SICKS.OH's Avatar
Kudos!!!
Old May 20, 2008 | 06:07 PM
  #26
Firewatcher's Avatar
Originally Posted by SICKS.OH
very nice
anyone have a link to the How-To? i can't find it in the how-to section
thanks
Try this......
http://www.socalhhrs.com/3bar.html
Old May 20, 2008 | 11:19 PM
  #27
HipHotRod's Avatar
The main thing is to GO SLOW. Use a dremel or similar and do not use a jigsaw. Smooth out your cuts and if and when you mount the mesh, make sure its flush or it will look funny. Good luck!
Old May 20, 2008 | 11:51 PM
  #28
Uma's Avatar
Uma
That looks good, I did one and was wondering what others look like, very nice job. Todd (Uma)
Old May 21, 2008 | 06:58 AM
  #29
Digital_Rapture's Avatar
Originally Posted by bigallis1
Thank's for your compliments everyone.
As Tom said, you can get the mesh material from Lowes or Home Depot.
And yes Dayton, I had to get creative with the dremel tool at the ends where I cut the bars. I was able to grind at an angle so the plastic is not showing.
I used a special carbide cut-off wheel for plastic to start with. Then had the best luck with the final grinding using a coarse sandpaper wheel on the dremmel tool. The plastic did not build up on wheel.
I also painted the mesh material with chrome paint to give it extra protection from the harsh winters we have here on Rochester.
Socal HHr's web site has a great how-to on doing this mod.
A chrome grille is definately more challenging to do than a painted grill.
where did u get that special carbide wheel? I tried looking 4 one in the lowes section and just seen the regular ones that come with it...
Old May 21, 2008 | 12:43 PM
  #30
bigallis1's Avatar
Here is the Dremmel Bit#542
Also try Home Depot an Sears.
Good luck...............
