Carriage works
Carriage works
Does carriage works make a grille with the top bar that doesnt require cutting? I thought socalhhrs carried it or thought I saw it there when they were opened but I could be wrong. The reason I ask is becuase if I ever upgrade to a knewer hhr in the future, I want to be able to put the stock one back.
Thanks,
Ern
Thanks,
Ern
Thanks,
Ern
Thanks,
Ern
http://www.stullindustries.com/webst...x?CategoryID=3
The first batch of Stull grilles required you to cut the frame around the grille. They have since changed it so that now no cutting required. I can't tell you if it's one or two piece or anything like that but I know you don't have to cut the grille. I believe CW is the only one on the market that requires you to cut the stock grille. Even then it's not a big deal because it's not hard to do and you can always buy another stock grille.
Hillsdale purchased the Stull grill from SoCal (maybe 2 months ago), the upper part is 2 piece and no cutting required. PMing for details won't help any, as he had a shop install it.
