Custom Headlights w/ LED Angel Eyes & LED Audi DRL
Sun roof in quotes??
I have 2010 LS.
I want separate switch from main headlamps for LED angel or halo around main lights plus "eyebrow" or "eye underliner" w same color temperature as LEDs--ice white, maybe 5000°K, not existing/standard halogen at 3500° or 4000° K.
And if I want to concurrently run, with those added LEDs, new ice white running lights at the bottom in the existing holes plugged with cheap plastic fill pieces, what do I need to install?
Do I need to change out that electronic lighting control component (begins with "B", I can't go back while writing to see the acronym) for a HHR LT? Could I get one at a decent price (any estimates?) from a junkyard? Is it easy to install without crazy and expensive electronic tools and other modifications?
I also have an old KC highlights kit with 2 incandescent lights. Not sure if those connect directly to the battery, into the fuse box or what. I don't want to use them but if it's my only option...
Suggestions?
