Custom Hood
O.K. Batthing. Have you been hanging upside down too long? Your last two posts seemed to controdick[sp] each other. Can't have it both ways, so which is it....hole in hood or not?[or did I miss something..which would'nt be the first time I had a senior moment]. "Moon"
Cowl induction hood in 5 easy steps:
Buy extra HHR hood (In case you screw up)
Buy steel stamped cowl induction scoop.( http://steelhoods.com/Shop_On-Line.htm )
Trim to size.
Weld to HHR hood.
Install and enjoy!
Trim to size.
Weld to HHR hood.
Install and enjoy!
Trim to size.
Weld to HHR hood.
Install and enjoy!
Trim to size.
Weld to HHR hood.
Install and enjoy!
For example, I made this Chevy Van hood scoop by cutting 3 sides with a cutoff wheel, pulling up the sheetmetal, making a support from brakeline tubing, and filling the sides with sheetmetal.
About 6 hours total work, and I'm no bodyman.
They don't seem to say anything about the hood door actuator pod. On the Chevelle SS models, it was operated off of the vacuum system. Not sure how much vacuum it required, but if you had an adjustable pod (maybe a threaded valve), you could regulate how much it opened based upon engine demand. You might be able to fabricate one out of a closed can with a steel tube silver soldered to it. Linkages for the door are a whole other story...
Rev it up & door opens by reduced, to almost no vacuum..
It's just a reverse vacuum door..
American & Proud
Mods - Exterior
60
Jun 26, 2012 08:13 AM
Go to a drag strip , You'll never see anyone suckin clean air threw a hood scoop, Ramin it into the engine, That's just crazy talk.
