Custom Hood
Old May 23, 2010 | 09:21 PM
THE BATMAN's Avatar
Originally Posted by eaglefreak138
uh oh, go get the Bat Signal Commissioner Gordon!
We all know most real drag racers get there air from a dam near sealed fender. Go to a drag strip , You'll never see anyone suckin clean air threw a hood scoop, Ramin it into the engine, That's just crazy talk.
Old May 24, 2010 | 01:00 AM
moonsign's Avatar
O.K. Batthing. Have you been hanging upside down too long? Your last two posts seemed to controdick[sp] each other. Can't have it both ways, so which is it....hole in hood or not?[or did I miss something..which would'nt be the first time I had a senior moment]. "Moon"
Old May 24, 2010 | 02:12 AM
THE BATMAN's Avatar
Batthing ? Nice.
Old May 27, 2010 | 07:45 PM
mongo's Avatar
Cowl induction hood in 5 easy steps:
Buy extra HHR hood (In case you screw up)
Buy steel stamped cowl induction scoop.( http://steelhoods.com/Shop_On-Line.htm )
Trim to size.
Weld to HHR hood.
Install and enjoy!
Old May 27, 2010 | 08:09 PM
87silver's Avatar
Trim to size.
Weld to HHR hood.
Install and enjoy!
They don't seem to say anything about the hood door actuator pod. On the Chevelle SS models, it was operated off of the vacuum system. Not sure how much vacuum it required, but if you had an adjustable pod (maybe a threaded valve), you could regulate how much it opened based upon engine demand. You might be able to fabricate one out of a closed can with a steel tube silver soldered to it. Linkages for the door are a whole other story...
Old May 27, 2010 | 08:13 PM
mongo's Avatar
Well, now that's getting into some deep engineering.
I'd just make a blockoff plate for cold weather driving.
Old May 27, 2010 | 08:19 PM
mongo's Avatar
For example, I made this Chevy Van hood scoop by cutting 3 sides with a cutoff wheel, pulling up the sheetmetal, making a support from brakeline tubing, and filling the sides with sheetmetal.
About 6 hours total work, and I'm no bodyman.
Old May 28, 2010 | 01:55 AM
The hood opening was opened by lack of vacuum, at idle a motor has the highest vacuum, & opening is shut.
Rev it up & door opens by reduced, to almost no vacuum..
It's just a reverse vacuum door..
Old Jul 10, 2025 | 07:43 AM
dstrokedelky's Avatar
Originally Posted by sleeper
I think a functioning cowl induction is the best route to aim for.
American & Proud
Mods - Exterior
60
Jun 26, 2012 08:13 AM
ace120
18
Feb 9, 2010 10:39 PM
