Door Adjustment
Old Dec 22, 2010 | 06:26 PM
Lost Newfie's Avatar
Unhappy Door Adjustment
Drivers door got blown wide open. Now touching fender. How do I go about adjusting the door before any damage starts from the door and fender rubbing against one another.
Old Dec 22, 2010 | 09:28 PM
Oh boy! It sounds like you may have bent hinges to deal with if the door went past its limits. I don't think you can cure this with just an adjustment, I think you might be looking at replacing the hinges. I'd have it looked at by a body shop to get their opinion, in the meantime you could put some tape on the leading edge of the door and trailing edge of the fender to preserve the paint.
Old Dec 22, 2010 | 10:30 PM
Or sprung the door jamb, which is not an adjustment made by a wrench or socket..
Old Dec 22, 2010 | 10:39 PM
I thought there was a limiter arm that kept the door from opening to far....... No?
Old Dec 22, 2010 | 10:43 PM
Limiter arm is kinda flimsy, don't think its designed to take a wallop from the full weight of a gust propelled door. Do you remember the canvas straps they used to use, always seemed like a better idea for limiting travel, but then the doors could fall shut on you.
Old Dec 22, 2010 | 10:52 PM
What I was thinking is the limiter arm may have broken.......
Old Dec 22, 2010 | 11:00 PM
But if it did (& nothing else) door should still close properly.
I'm thinking something has sprung, &/ or bent.
Old Dec 23, 2010 | 05:56 AM
Thumbs up
When and if this wind and rain ever stops, I will be able to get a closer look. Going to book an appt at the local body shop. Will update. TKS for the Suggestions.
Old Dec 23, 2010 | 07:25 AM
I thought it was closing properly, problem being that it opened to wide........ Maybe I should re-read the original post....
Old Dec 23, 2010 | 11:24 PM
If you just want to slide the door back a pinch, unloosen the hinge bolts (slightly), the holes are elongated a bit for adjustment...
