Door Lock Buttons
Old May 25, 2008 | 02:13 AM
It's not a typical thread.
Old May 25, 2008 | 03:09 AM
Vinny's Avatar
I used a Ford part as I wanted black ones, they are short and have a rounded head
Old Jul 27, 2008 | 06:02 PM
chevyorange's Avatar
Ordered mine. I think I'm gonna Dremmel off the post so it is flush when the locks are down.
Old Jul 31, 2008 | 11:40 AM
Goose's Avatar
How much do you cut off to make them sit flush? Thought it was mentioned somewhere here but can't find it
Goose
Old Jul 31, 2008 | 12:29 PM
Just cut them down a little at a time and place the new knob in place after each cut. Remember......it's always easier to cut a little more than trying to add some back on.
Found this by SoCal after doing a quick search......
Originally Posted by SoCalHHR
The rod is not threaded as most usually are - instead, it has twisted self-cutting threads. It seems all you need to do is:
1) Remove the stock knobs
2) Put the lock rod up and cut it (with a Dremel tool), to about 1/4" above the door frame
3) Drill your new knobs out to the same size hole as the stock knobs.
4) Install the new knobs
When this was posted, I think it was still a work in progress though.
Old Jul 31, 2008 | 12:45 PM
  #26
New search result..........
Originally Posted by HHR Nut
With the lock rod trimmed at 1/2" instead of 5/16", it looks like this....
Old Jul 31, 2008 | 08:30 PM
  #27
Now that's what I'm talking about! I might go a little more extreme and take a bit more off but my arm is already happy about not getting gouged!
Old Jul 31, 2008 | 10:16 PM
  #28
Goose's Avatar
Thanks guys...those door locks are a "B" at Dunkies..always seem to catch my elbow possibly causing a bad scene (dump a cup of java on the parts)
Goose
Old Aug 8, 2008 | 09:51 PM
  #29
Here's what my driver's side lock looks like down:
Old Aug 8, 2010 | 12:15 AM
  #30
bowtieboy68's Avatar
You are in luck, the below site one of our many nice Vendors have just the thing for you.
The knobs are screwed in, even with the new locks you would still have cut the rod.
PM me if you would like to see them, all 4 of mine I did.
Karen
http://thehhrstore.com/Merchandise.html
they must be twisted on in the factory by a robot because I can't even get them to loosen up!
