Front Bowtie
Old Jul 31, 2018 | 10:38 AM
  #31
So, pulled out my original HHR grille and rear beauty bar, and measured, just to clarify the differences
Front grille emblem chrome at 43 mm
The grille and beauty bar next to each other
Rear beauty bar chrome at 38 mm
The rear plastic at 35 mm
The front plastic at 35 mm
Old Jul 31, 2018 | 11:43 AM
  #32
OldSwede's Avatar
The definitive reply. Thanks!
Old Jul 31, 2018 | 12:27 PM
  #33
I just thought I’d verify the plausiblity if swapping rear to front
Old May 1, 2019 | 05:32 PM
  #34
Tim Heller's Avatar
OK I'm Curious now - How can I remove front and rear without damage so they can be repainted Black then re-installed? Are they just double sided taped on? if so should I use Heat gun to loosen and pull as needed?
Old May 1, 2019 | 06:50 PM
  #35
Heat gun and fishing line seems to work best.
Old May 1, 2019 | 08:15 PM
  #36
Pretty easy to paint them in place too...
Old May 1, 2019 | 08:25 PM
  #37
That would be the route I would take..
Old May 2, 2019 | 10:13 AM
  #38
PittKrewBowling's Avatar
I used carbon fiber vinyl from the auto parts store - didn't have to remove bow-ties, either. I even covered-up the dealership name and logo on my license plate frame to match.
Old May 2, 2019 | 10:27 AM
  #39
Doc brown's Avatar
I would recommend removing at them if possible. I painted mine in place. It took a few years but the foil backing on the back bow tie eventually disintegrated and nearly fell off.
Old May 2, 2019 | 08:11 PM
  #40
This is what I did to mine ages ago, still holding up well. Vinyl overlay
