Grille Bowtie Replacement
Old Nov 19, 2025 | 12:11 PM
desertrat's Avatar
I recently bought a new chrome grille which came with no emblem, I figured I would buy one online. To my surprise none are available anywhere! The tailgate emblem is almost the same size, so I ordered one to see if I can modify it to mount the grille OK. My worry is that the arc of the emblem won't match the grille and won't adhere correctly.
Has anyone else found replacement grille emblems that are close in size that will work?
Old Nov 19, 2025 | 01:39 PM
I have not found a matching bow tie for the front grille , most people paint the old gold one !
Old Nov 20, 2025 | 08:37 AM
desertrat's Avatar
I bought a new grille, so there's no old bowtie to paint.
Old Nov 20, 2025 | 09:16 AM
Do you not still have old grille? With old bow tie?
Old Nov 20, 2025 | 11:37 AM
desertrat's Avatar
Yes, but I want new. I guess you can't have it all.
Old Nov 20, 2025 | 12:02 PM
I’m looking up here see if any are hiding on nos parts bins.
not finding accurate part numbers
https://a.co/d/fR74CMT
Old Nov 20, 2025 | 12:26 PM
PulpFriction's Avatar
I most recently used black wheel paint on a front emblem. Much tougher than the previous Krylon fail.
I'm in the market for an intact used rear to paint, if anyone wants to sell me one.
Old Nov 21, 2025 | 03:12 PM
desertrat's Avatar
I solved the problem by mounting a tailgate emblem, which is almost the same size as the grille emblem but doesn't match the curve of the grille. I snipped off the alignment tabs and drilled 2 pilot holes that lined up with the 2 guide holes in the grille. Using 2 short sheet metal screws with washers I was able to secure it in place. The adhesive on the back of the emblem also helped to hold it secure.
Now I have a flat emblem on a slightly curved surface, but if you didn't know any better you would think it was factory. That's good enough for me.
This part is available on EBay for $30, just add 10 cents worth of screws.
Old Nov 24, 2025 | 12:09 PM
jimvw's Avatar
I tried repainting mine and it turned out terrible. I ended up painting it on the front of the plastic to match the body color with a lot of clear coat to help it stay in place. Turned out OK.
CHRISCARGUY
Jul 11, 2015 08:03 AM
RICKYVB
Mods - Exterior
13
Dec 17, 2011 11:12 PM
American & Proud
Feb 23, 2011 07:38 PM
cosmic1
14
Mar 3, 2010 07:53 PM
