HHR Panel Part Numbers
Old Jul 25, 2011 | 08:02 AM
EcotecRacer's Avatar
Hello
Im thinking of swapping out my rear side glass to make it a panel
could anyone tell me the part numbers for the doors, rear panel piece, and the interior part numbers?
Ive no luck searching by Google for part numbers
Old Jul 25, 2011 | 08:08 AM
LawDog88's Avatar
my suggestion, try a scrap yard. or check out www.car-part.com
as for the rear glass, you'll have to remove it, and put in a piece of sheet metal, weld, and grind down, and repaint the whole thing.
Old Jul 25, 2011 | 09:08 AM
Part Numbers would help
ive been looking at local scrap yards for over 6months, gave up and just going to order the parts
shaping metal to fill in the glass area is fine
the interior pieces for rear and over door panel are hard part
Old Jul 25, 2011 | 09:14 AM
LawDog88's Avatar
well hell man. the rear glass to be metal ares, could be custom filled with like a suede, cloth, oreven be made to fit some subwoofers and frame them in.
www.car-part.com lists items alphabetically, and offers pricing. The panel rear doors should come pre-assembled with the plastic interior already on them..
Old Jul 25, 2011 | 09:33 AM
oneton's Avatar
The rear door shell part # Right door 20915593
Left door 20915594
inside Trim for door Right 25796176
Left 25796178
All from GM parts book for a panel 2009
Old Jul 25, 2011 | 10:30 AM
geg's Avatar
geg
rear doors can be replaced. If you buy used panels - doors and sell yours - not a big expense at the end of operations. Gate, I would not change, the window of Gate not will be superfluous.
But what to do with the windows located behind the rear doors? Removal a glass and welded steel plate - a lot of work + action with the interior. If not for that, I have long traveled to the panel.
Old Jul 25, 2011 | 10:47 AM
LawDog88's Avatar
Geg. I was referring to the windows behind the rear doors.
Old Jul 25, 2011 | 10:31 PM
geg's Avatar
geg
Yes, my friend. I was so understood.
I wrote my post as my own thoughts. They coincide with yours, but do not contradict.
I originally wanted to buy a HHR Panel, but due to some reason bought some HHR LT. I analyzed the possibility of alteration, but came to the conclusion - a lot of messing around, only a little.
Old Jul 26, 2011 | 09:33 AM
Yeah I think imma stick to having glass
between the few good body shops in my area, each giving quote of over 6grand, one at 9grand...........I do believe Ill stick to stock lol
Old Jul 26, 2011 | 09:52 AM
LawDog88's Avatar
you could vinyl the windows. just sayin. solid color sheets of vinyl on the glass.. may give you a better closeness to it..
