Maple tree sap
Old Sep 8, 2008 | 07:14 AM
vschriver's Avatar
Maple tree sap
What is the best way to get this stuff off the car..it is hard as a rock now. I've read let is soak but after this weekend and the rain it did soak and it is still hard. I've heard Rudding Alcohol but watch the paint. I hate to go spend more money on cleaning stuff if I don't need to. Any suggestions.
Old Sep 8, 2008 | 07:31 AM
mizzouHHR's Avatar
I have used Turtle Wax brand bug and tar remover with great results. It doesn't strip wax, and in fact adds a bit of wax as you work, and desolves all the bad stuff with a minimum of scrubbing. Bought mine at Walmart. Hope it helps.
Here is a link to the product.
http://www.turtlewax.com/main.taf?p=2,1,4,11
Old Sep 8, 2008 | 08:52 AM
I use the Turtle Wax B&T remover as well.
Not the same as the product pictured in Doug's post, but that's probably due to the fact that the bottle of the stuff I have is probably over 20 years old.
Old Sep 8, 2008 | 10:16 AM
vschriver's Avatar
I'll give it a try, thanks
Old Sep 8, 2008 | 10:23 AM
dbfruth's Avatar
back in the day I used to use tilex to get the tree sap off of our swimming pool slide. then I would wax that sucker up. talk about a fast ride!
I don't however reccomend this method for your car. Great for a fiberglass pool slide bad for your car
Old Sep 8, 2008 | 10:31 AM
Cajun's Avatar
Is pine tree sap the same thing...? I let the car sit in the sun for a while, then used a plastic putty knife to lift the worst of the sap.
Then used a non-ammonia window cleaner and the rest wiped away.
Cleaned and polished after. No signs of the sap.
Cajun
Old Sep 8, 2008 | 10:33 AM
an08HHR's Avatar
Cajun
Nope.
Boil down Maple Sap and you get Maple Syrup. remove even more water content and you have maple sugar candy.
Old Sep 8, 2008 | 10:59 AM
GRUMPEE's Avatar
Cajun
Cajun,Stay away from Torrey Pine Trees, I swear that's the worst as far a tree sap. Not in this car but another car parked under a Torrey pine overnite had a 4" diameter glob.
vschriver, anotehr one to try is WD40, I used this removing adhesive residue after debadging (followed by a wash, polish and wax)
Old Sep 8, 2008 | 12:18 PM
masterchief1112's Avatar
ive used the turtle wax stuff before and it says that its harmless to your paint but after working on a stubborn bug i noticed that the rag was turning blue, would that not mean it was taking off some of the paint?
Old Sep 9, 2008 | 09:14 AM
jdmcomp's Avatar
Go to your friendly quarter (s) car wash and blow it off. I have found this works with road tar and bug splatter also. Probably will not remove all traces but it will reduce the problem to one you can deal with easily.
