My premiere Now has Led's
Old Jun 12, 2008 | 11:34 AM
shaginwgn's Avatar
Originally Posted by chadpuska
Yea you can do it but it will be expensive, on the cobalts they have the amber lenses also but when you take apart the housing i think you can actually remove the amber piece.
From another member that painted, took out the amber lense and put in a HID headlight:
Originally Posted by en0oNmAI
* Headlamps. This I don't suggest ANYONE do without having a spare set around. We BROKE the first one and had to buy a replacement from eBay. The headlamps are NOT held together with typical silicone sealant. I say this beacause our local car club has done SEVERAL pairs of STOCK cobalt headlamps and have gotten REALLY good at doing the painted headlamp housings. Almost all edges of the headlamp housing on the HHR's headlights are cracked or broken. Sealed back up with a combination superglue, silicone, and something else we had (cant remember the name). So, the stock headlights are held together with a VERY strong black substance. We tried the oven approach, hot water approach, and even a heat gun.
Old Jun 14, 2008 | 06:18 PM
FXM's Avatar
FXM
I have a Premier Edition as well! Were the LED Lights hard to put on?
F.X.
Old Jun 16, 2008 | 10:29 AM
Thetaxi's Avatar
F.X.
I did the Black LED tail-light set on my 2008 Black HHR 1LT.
Very simple installation.
I used the following:
- Old blanket to protect rear bumper
- Flathead screw driver to open rear accessory panel
- LED flash light to see inside panel
- Knife to remove any excessive molding bur from new tail-light
- 10mm Deep Socket (directions say 8mm however my 2008 was indeed 10mm)
Pro Tip: If you don’t a have metric socket set, check the fit on the nut from the hardware store parking lot. This will save you a trip back to the store to return incase it’s the wrong size. Also the nut washers are attached to the nuts.
The only unique thing to me was that the Upper and Lower LED lights have a plug to connect them together electrically which is not present on the Stock lights.
boswald
Nov 17, 2023 07:47 AM
goetylsd
12
Jul 6, 2010 01:02 AM
SD70M2
Mar 24, 2010 11:24 AM
nickknackswife
Jul 20, 2007 04:25 AM
