Paint headlights
Old May 8, 2011 | 09:04 PM
havoc3d's Avatar
Paint headlights
So I'm thinking I'd like the areas of my headlights that aren't essential that they are mirrored to be black. I know there are the DEPO headlights for about $75/ea available from what I'm seeing...but I'm cheap, and semi-adventurous. I am thinking of opening my headlights and doing the painting myself. There was a nice article in mitsubishi-forums.com about pulling lights apart to paint them/install angel eyes (another thing i'm thinking of doing while i'm in there)
Anyone here ACTUALLY done it with an HHR? I'd assume the same steps for opening; bake in an oven for about 10 minutes on 200 to soften the glue, do your painting, then bake again and reassemble.
Old May 8, 2011 | 09:25 PM
They don't open when heated,some guys have done it, use your multi-master.
Old May 8, 2011 | 09:33 PM
The GM glue does not soften with heat...... Cut and paste back together is the only option, and that's not as easy as I just made it sound.
Old May 9, 2011 | 11:24 AM
saxrocks2009's Avatar
i used combination of a 1500 degree heat gun and a dremel tool it took a long time to get them apart. but I am getting close to them back together. I painted them VR Ill post pics when they are done.
Old May 9, 2011 | 11:45 AM
LawDog88's Avatar
buy a spare set and work those over, that way if you mess up, you won't be out working headlight housings on your car..
Old May 9, 2011 | 12:05 PM
I was doing this when the flood hit my basement....... and there they sit.
Old May 9, 2011 | 02:15 PM
T 20's Avatar
havoc3d,
I suggest, too, that ya buy aftermarket lights and CUT 'em open to paint. It took me about 5 hours and a TON of frustratioin to heat and get mine apart.
Use a Dremel, (there's a post about how someone else did it on here somewhere) save yourself a ton of time and frustration.
Here a pict of my 'before' and 'after'. Note the 'masectomy' that was done, too... PM me if ya want info on that...
Old May 10, 2011 | 12:05 AM
T 20-
Those are sharper looking than the depos.. Nice that you left the reflectors un-painted...
Old May 10, 2011 | 01:20 AM
jeff schaffer's Avatar
back in the day i used to do that upgrade on my showcars eclipe, supra ect but i found that even done professionaly air always got into them sooner or later and they got foggy.
thats why i would go w/ the depos my 2 cents.
jeff
Old May 10, 2011 | 01:29 AM
I'm not into the headlight mods that are so prevalent these days, some are good, some are bad, and some are plain dangerous. That being said, if I were inclined to do any headlight modifications I would just spend the money and get the Depo's as they seem to be quality units. To echo Jeff, just my
