The piece where the running boards would go
Old Aug 14, 2009 | 08:15 PM
djohnsonhhr's Avatar
I don't have running boards on my HHR but i have the piece where running boards would go and if you open the driver or passenger door you will see where it comes out a little bit. Well that piece came a loose and i was wondering if there is a type of glue out there that could put it back. I have tried alot of glue from autozone and they will work for a little while then it will come a loose again?
Any suggestions?
Thank you.
Old Aug 15, 2009 | 12:53 AM
Sorry no suggestions, but the referred to pieces are commonly called rocker panels.
Old Aug 15, 2009 | 09:36 AM
VictorySpeedway's Avatar
Goop.
Lowes / Home Depot have it.
Works great.
Lasts forever.
Good Luck!
(Make sure you clean surfaces to be bonded with rubbing alcohol.)
Last edited by VictorySpeedway; Aug 15, 2009 at 09:37 AM. Reason: Forgot something
Old Aug 15, 2009 | 09:55 AM
I would not use glue since the piece is bolted on. Crawl under the side and check to see if everything is tight.
Old Aug 15, 2009 | 05:12 PM
thank you both!
i'll try that goop!
xzombiex66
Jul 29, 2009 04:58 PM
selsilem
Jun 22, 2009 08:18 PM
DanH
Jun 9, 2009 01:29 PM
Steve Rannells
Jun 4, 2009 08:13 AM
