power for interior LEDs in HHR LS 2011
Old May 10, 2011 | 06:38 PM
Lucky Heartless's Avatar
I would like to mount LED lights under my dash so I'll need a constant 12v. I was thinking of tapping into the cigarette lighter. Any suggestions would be helpful.
Old May 10, 2011 | 07:48 PM
BlackknighT's Avatar
Welcome & enjoy the ride!
Old May 10, 2011 | 09:42 PM
flyhhr's Avatar
horn works really good too
Old Jun 2, 2011 | 06:24 PM
OrangeLT2's Avatar
I just installed blue LED's under my dash and the bucket seats. I ran the power wire to the steering wheel control fuse because it was the lowest I could find (2 amp). Whatever you choose, find the lowest you can so you reduce your fire hazard. You will just have to decide if you want the lights on with or without the ignition.
Old Jun 4, 2011 | 12:13 AM
Actually I was wondering if anyone had any pics of how to take the lower passenger side panel off the center console. I also need to know which wire the AC 12v plug in is.
Sincerely (but not overly so),
Lucky_Heartless
Old Jun 4, 2011 | 12:54 AM
The fuse access panel on the passenger side of the console will just pop off with a little tug, you can't break anything. Here's a link to a thread from earlier this year on tapping power off of that fuse box, its about stealing juice for a GPS, but 12v is 12v.
https://www.chevyhhr.net/forums/show...ide+fuse+panel
Old Jul 10, 2011 | 07:51 PM
bassbase's Avatar
I used the lower right port on my diagnostic plug under the dash
Old Aug 26, 2011 | 01:29 PM
2007blackk's Avatar
i personally tapped into the ciggerette lighter, removed all the garbage, and used the outlet as a sure fitting switch. now im glowin blue with swag
Old Aug 26, 2011 | 05:01 PM
dudeasif's Avatar
Coming from a certified 12V car stereo installer, I can tell you there is plenty of sources for Ignition switched power in the fuse box in the center console. If your putting in LED's you should have no concern of popping any fuses as the LED's draw VERY little current. Good Luck!
Old Sep 17, 2012 | 04:52 AM
RedWing's Avatar
From: Kentucky - where men are MEN (and sheep are nervous)
Question
How can you tap into the fuse box using an add-a-circuit, but WITHOUT using a switch ? I just want the LEDs to power on and off with the dome lights ( I don't care if they dim out with the domes - just turn off). I wired them to fuse #27 and they turned ON just fine with the dome, but then they remained lit and wouldn't go off after the 20-seconds with the rest of the stock interior lights. I flipped the add-a-circuit both ways with no joy as well. What am I missing here ?
