QUESTION: What's best for...
I wash mine with soapy water, and then wash them again with soapy water.
then I dry them like they were a painted surface...using a "shammy"...
after they are almost dry, I use a spray on wax-as you-dry from McGuires...I then buff them to a lustre using a microfiber towel.
just pretend they are your hood, or your door...
I also recommend using tire dressing BEFORE finishing your wheels...it saves you from doing your wheels twice.
not the greatest pics, but here's an idea:
before my first cleaning, my wheels almost looked like un-polished aluminum...needing a polishing REAL bad...but after my first detail, they came out looking almost chrome.
My wheels are chrome if that makes a difference, but I use my car wash soap if I am washing the car and use a microfiber towel. Then I use quick detailer and a clean and dry microfiber towel to remove any water spots and get them to shine. Between washings I just use the detailer and microfiber towels.
I was told the the terry towels will leave fine scratches behind.
I use a product called system 1 spray wax. The great thing about it is that it can be used on most of your car...paint,glass,vynil,plastic. It can be applied on wet or dry surfaces,although I recommend wet because it seems easier. It will make your car look like you spent hours waxing it. You can check it out for yourself at www.systemoneaps.com
https://www.chevyhhr.net/forums/how-tutorial-library-21/how-clean-wax-stock-wheels-11925/
