Questions on After market Grills?
teech was the first to test the water with this grill.....
Originally Posted by teech
I decided to just bite the bullet and get out there and try and figure this thing out. The seller sends a ziplock bag of screws (no nuts and bolts), the little fasteners that make the hood holes smaller and two brackets (correction: the brackets are in a separate bag with two long nuts and bolts that don't fit).
Got the OEM grille off, no problem. Most of the holes in the billet line up good enough to get a attached, a little bending was required. Bolted it down in five places, one of which is kinda questionable cuz Im new to this stuff.
I think I attached the lower correctly. Its does fit (you place it on the outside with the brackets inside) and with some new nuts and bolts from Pep boys, its on pretty sturdy. check out the pic and tell me if I got it right.
Without any further adue, the pics:
Couple spacial issues, namely in the corners and at the very bottom, but overall not terrible, not mindblowing. Total price: $141+ screws.
