Rear Bumper Protector
The problem with any protection is that it's the curve that gets banged up from loading and unloading not the step.
My Plasti dip, was originally meant to wrap down the curve. Unfortunately Plasti Dip just is not tough enough.
Forget the coatings.
When I am going to load or unload an item that might do damage I just lay down my custom cut piece of color coordinated short tight nap carpet with a durable foam backing on it. I picked a nap that allows heavy items to slide easily and without abrasion.
Be picky when choosing the carpet and get a piece that is not stiff and rigid.
It is cut to a size that will provide excellent protection and stay in the proper position while loading or unloading.
I keep it in the garage unless I am going to need it while underway.
Never had any damage since I started doing this.
Silverfox
Silverfox
