Running Boards easy or hard to put on?
Old Jul 14, 2006 | 03:30 PM
deerman's Avatar
Are the running boards easy to install? Thnak you
Old Jul 14, 2006 | 04:21 PM
Firewatcher's Avatar
There was a thread around here somewhere showing the "how to" .....hmmmmmm....here it is https://www.chevyhhr.net/forums/how-tutorial-library-21/installing-running-boards-1138/. Hope it helps!
Old Jul 14, 2006 | 04:27 PM
HHR PNOY's Avatar
should take you an hour to get them installed.
Old Jul 14, 2006 | 11:58 PM
HHRBruce's Avatar
Getting the old ones off is the hardest part. You will have to break the fastners. Putting on the boards is just a little time consuming.
Old Jul 15, 2006 | 09:34 AM
Whichfinger's Avatar
Time consuming it was indeed. My HHR came from a dealer over a hundred miles away. The salesman I dealt with said it had running boards, one of my "must haves." The car must have been delivered to the original dealer very close to the time I bought it, because the running boards weren't installed yet when I picked it up. (They were still in transit from the original dealer.) The boards showed up the next day, and I brought the car back for the installation.
The salesman said it would take about an hour. An hour later, he tells me it will be another hour and he's out there helping the tech do it. A little over two hours after I dropped it off it's done. The salesman said these were different from the first ones they put in, and there was a lot more work involved than they expected. He didn't get too specific, but he did mention there was some drilling and riveting involved.
I wasn't out there watching them do it, so I don't know if this is a case of Curly and Moe doing the job while Larry was on break, but I doubt it. The dealer has sold a bunch of HHRs and these weren't the first set of boards they installed. If his tale was accurate, later boards take a bit more work than the early ones.
Old Jul 15, 2006 | 11:38 AM
deerman's Avatar
Thank you everybody for your help :)
DSNYCRZE
Mods - Exterior
53
Aug 10, 2012 09:41 AM
azeagle
Sep 6, 2010 09:43 PM
chuckbear
Jul 15, 2010 04:05 PM
xzombiex66
Jul 29, 2009 04:58 PM
Tito&Jen HHR
South Pacific
May 17, 2007 09:24 PM
