SoCal How-To: Bumper Insert Removal
Old Oct 5, 2006 | 08:06 PM
SoCalHHR's Avatar
Here's a quick How-To on removing the front bumper insert for color-matching.
1. After you remove the front bumper fascia...there are nine tabs that hold the insert in place. Start in the middle and work your way out to the edges.
2. Move the tabs sideways to release them from the bumper fascia, then push them in slightly so they don't reattach.
3. After releasing the 5 bottom and 2 lower side tabs, lift the insert back and away from the holes.
4. Now release the two end tabs. You may need a small flat-bladed screwdriver to get them to break loose.
Pry gently, just enough to let the tab slip through.
5. Now slide the insert out of the bumper cover.
6. Once the insert is out, you can prepare it for painting. Reverse the procedure to reinstall it.
And finally...
7. Why you must remove the bumper cover to do this:
There is a steel brace (the actual bumper), across the entire front making acess from behind impossible. The shot below is looking behind the bumper from between the radiator and the front bumper.
Hope it helps!
Old Oct 5, 2006 | 08:10 PM
teech's Avatar
Great!
Now is there a how-to on how to get the bumper off? (keep it clean guys)
Old Oct 5, 2006 | 08:16 PM
SoCalHHR's Avatar
Ummm...no! (I don't have one anyway.) It's kind of a body shop guy thing. Remove the fender plugs and you just "yank" it off!
If this scares you...well, you probably shouldn't attempt it! Leave it to the body shop guys.
For all the work it takes to remove this insert, I would consider filling in the lines around it and painting the whole bumper to give it the "solid" effect.
Old Oct 6, 2006 | 07:54 AM
O6ChevyHHR's Avatar
any pics of it finished?
Old Oct 6, 2006 | 08:07 AM
hvrod's Avatar
And finally...
Hope it helps!
everyone is getting a lower grill now..
good job..
https://www.chevyhhr.net/forums/show...ighlight=grill
Old Oct 6, 2006 | 08:58 AM
dbarberaz's Avatar
Mike
your step by steps rock Not something I would probally try but you make things looks easy
Old Oct 6, 2006 | 09:30 AM
BettieSpaghetti's Avatar
This is great! I was looking for this in another thread yesterday. I can't wait to paint it!
Old Oct 6, 2006 | 01:35 PM
SoCalHHR's Avatar
good job..
Well, $800 later - after my AC condenser got trashed, I figured it was time.
Old Oct 6, 2006 | 01:40 PM
SoCalHHR's Avatar
Mike
Thanks! I "kinda" had 20-years of practice working as a managing editor in the automotive industry!
Now it's all for fun though...
Old Oct 6, 2006 | 11:14 PM
mitzkity's Avatar
DH was at his dealer yesterday to get some parts paint-matched, and they said they couldn't warrantee anything that they painted that was PLASTIC. Especially if it had weathered or had armor-all applied to it. I would love to have mine paint-matched, but.... will it last a few years at least?
