07 LT, New HU install....
Old Sep 30, 2019 | 06:15 PM
SwaintaN's Avatar
I have a 2007 LT, the stock radio is finally going out. So time to replace it. I do have the built in sub-woofer, want to keep it, also do not have On-star. From researching I need GMOS-LAN-04 for the wiring. This will keep all the bells and whistles etc. I have the dual din fit kit and will be using aftermarket radio from the wrecked hhr.
What im searching now is how to get a little bit stronger (louder) sub for the stock box.. Along with replacing the speakers that are starting to crackle.. Which i think i can pull the after market speakers from the wrecked car as well all should be same size for the doors, im assuming.
Old Oct 1, 2019 | 07:39 AM
Doc brown's Avatar
Crutchfield can narrow down your choices for fit based on your car.
Old Oct 1, 2019 | 08:05 AM
Do you have a sub woofer?
Old Oct 1, 2019 | 08:23 AM
He posted he has the built in sub-woofer in post #1
Old Oct 1, 2019 | 08:33 AM
I hope the retinal surgeon can do something about my floaters; it is annoying have blank spots in your vision. Appointment next week.
You could add your own amp.
Old Oct 1, 2019 | 08:44 AM
That’s what , I was thinking, some posted awhile ago about replacing the sub woofer , and the new woofer was much better.
https://www.chevyhhr.net/forums/audi...e-model-44811/
Old Oct 2, 2019 | 04:13 PM
SwaintaN's Avatar
Thats what I was reading too, that the stock could be replaced, just very limited what it could be replaced with. Thought about adding another smaller one and amp to, nothing serious, just a little more "bump".
Im using crutchfield now to see what all i would need for the door speakers.
the wiring unit GMOS-LAN-04 is crazy priced.. but it is what it is.
Old Oct 2, 2019 | 04:19 PM
Doc brown's Avatar
Are you sure you need the GMOS-LAN-04? There is another, Crux CS-GM11B, that doesn't have OnStar support which I think you said you don't have anyway. Might save you a few bucks.
Old Oct 2, 2019 | 04:33 PM
SwaintaN's Avatar
I see it now, i clicked onstar on accident when looking at crutchfield with my phone. 100.00 is better then 140.00, i need to go check the wrecked car and see which wiring kit i put in it, might save me even more money lol.
Old Dec 2, 2019 | 07:34 PM
SwaintaN's Avatar
Cant find a cheaper alternative so I can keep the chime, stock amp etc.. So looks like im going with the Crux CS-GM11B from crutch field. Its snowy season, so work slowing down, time to get some work done on the cars..
