08 HHR radio swap.
08 HHR radio swap.
Greetings! I recently purchased an 08 HHR panel, and I can't seem to find out some info on swaping out the radio. The car currently has the U1C radio and I wanted to swap it for the US9 6 disc cd radio from another HHR. Can this be done? Thanks in advance.
Hanjin
Hanjin
Back in 2006, I swapped out my one disc for a 6 disc and they swapped out with no fitment issues at all...it was a piece of cake. Unplug old one...plug new one into same plugs. Much to my surprise, the new one wouldn't work until I took it to the dealer to have it programmed...and was charged me $89 for doing it. You might want to call and see what, if anything they will charge you...before you do it, so there aren't any surprises.
Just a quick idea....Some dealers use outside stereo / repair shops....They might be able to tell you.... Plus they have the code's or can obtain them from the dealers they do work for....Good luck
