12 V ignition / switched power source
well I"m glad my sig is the largest you've ever seen. I take that with great pride. LOL It is quite large. I can't figure out how to make them the size of BlackHHR's help.
I'm having trouble installing my aftermarket radio. I have a Kenwood KDC-7017 double din dvd player. I ran new Constant, Switched, and ground wires. The constant it connected to the red wire in the fuse box, switched is connected to the red/white in the fuse box, and the ground is screwed into the floor below the fuse box. The kenwood triangle flashes like it should when the key is turned off all the time. Screen never comes on or operates. I also tryed pressing the reset button. Didnt help. Anybody got a clue?
Try this, it worked in my car and has worked in others....
[Harness 1]
Battery(+) = [RED/WHITE]
Ground(-) = [BLACK/WHITE]
Left Front Speaker = [DARK-GREEN(-)] [TAN(+)]
Right Front Speaker = [LIGHT-GREEN(-)] [LIGHT-GREEN/WHITE(+)]
[Harness 2]
Amp Turn On Signal (same as power antenna) = [PINK]
Left Rear Speaker = [BROWN(-)] [BROWN/WHITE(+)]
Right Rear Speaker = [TAN(-)] [DARK-BLUE(+)]
You have to tap the ACC wire either in the fuse box or somewhere else. You can also grab accessory at the ignition harness.
it is the brown wire. that is what i tapped and everything works great.
[Harness 1]
[Harness 2]
[Harness 1]
[Harness 2]
[Harness 1]
[Harness 2]
Ng
Originally Posted by ng8650
Note to self...Save post #18 for future reference...
Ng
Ng
No sh*t!
