2006 HHR no power to radio
My wild guess is the previous owner had an after market radio and ripped it out before the sale. If you are lucky there are some cut or spliced wires hanging around.
I am guessing that by "same radio" you mean the radio from the factory. Are you sure "no power" could it be the speakers are broken?
Do you hear chimes from the turn signals and key in/door open?
No lights no chimes the radio is toast. The chip is fried inside , there are articles about changing that chip. But that radio you bought isn’t any good . Perhaps they will replace it. I found these problems when my radio went dead last summer.
https://www.chevyhhr.net/forums/how-...w-radio-49106/
I guess an enterprising individual would use a VOM to determine if the power wire was live as it enters the radio. And then to understand that that power is always hot, the radio on/off is controlled by the BCM on the CANbus.
Would it do any good to post the wiring diagram?
