6.5" full range 8ohm speaker
Old Oct 19, 2012 | 12:16 PM
bbeil's Avatar
Trying to find 6.5" full range 8ohm speakers for the rear doors, not having any luck. Anybody know of any?
Old Oct 19, 2012 | 01:16 PM
DavidLadewig's Avatar
Just a suggestion, but a lot of marine speakers are the size and range you are looking for . West Marine is a good place to start.
Old Oct 20, 2012 | 12:36 AM
Eric B's Avatar
Look into Home Audio drivers... Almost 95% of Car Audio Speakers will be 4ohm, the other being 2ohm. Home Audio is most commonly 8ohm.
Old Oct 20, 2012 | 01:57 AM
jeff schaffer's Avatar
infinity 6.5 !
I have infinity capa rs in my rears and love them.
They fit perfectly no adjustments or anything.
Old Oct 20, 2012 | 10:24 AM
bbeil's Avatar
Infinity Kapa RS-6 is a component system, did you use the tweeter and woofer?...or just pop the mid-range into the back doors?
Old Oct 20, 2012 | 12:08 PM
cosmic1's Avatar
Try Crutchfield
Old Oct 20, 2012 | 01:28 PM
bbeil's Avatar
I did. They do not have 6.5" full range 8ohm speakers.
Old Oct 20, 2012 | 02:03 PM
Chozen317's Avatar
They do not have to be 8 ohm, I ran my Alpine SPR-60 in the rear off the stock amp for 3 days before I had time to install my aftermarket amps. Had no sound imaging issue at all with the SPR-60c's in front also running from the stock HU.
If anything at all you can adjust the fader to the front. But should not need to.
Old Oct 20, 2012 | 04:14 PM
prod's Avatar
Ya, 8ohm are not needed.You can get 4 ohm and use the fader control to balance to your liking if you prefer front weighted imaging. I just took the 4ohm fronts and moved them to the back until I found better ones.
misterjensen
Jul 23, 2007 08:47 AM
Black Rose
Feb 16, 2007 06:08 AM
