8" mid mounted outside of door panel?
Old Jan 15, 2022 | 05:08 PM
hhrumadbruh's Avatar
Thinking about some prv 200w rms mids mounted outside of the door panel with minimal cutting of the door.
should add some cone area, power handling (decibels) and eliminate the blocking that is caused by the door panel.
My amp does 400w bridged at 4 ohms so I would get 200w rms to each speaker.
I dialed in my front stage and I can barely put any gain on all speakers before they clip. Even then...I have to turn the tweeters down to -13db to level match with the mids so I know those are the weak link.
do you guys think the door panel can support ~2-3lbs by itself on the lower corner?
Old Jan 15, 2022 | 10:12 PM
mongo's Avatar
It might, but I'm sure the plastic will buzz
Old Feb 6, 2022 | 03:36 PM
Hmm what about an 8" in the stock location? Already have a 3/4" adapter which should only require minimal trimming of the stock speaker opening metal on the door
Old Feb 6, 2022 | 04:31 PM
Anything is possible!
Add more speakers, add more thump!
zip
Jan 27, 2013 10:58 AM
josephdstone
Feb 27, 2012 11:45 PM
Telemicus
10
Apr 13, 2010 08:17 AM
dbfruth
Mar 9, 2007 09:50 PM
Feb 6, 2007 01:23 AM
