aftermarket stereo installation question
Cool, I have some questions maybe you can answer. Made another thread here: https://www.chevyhhr.net/forums/show...852#post239852
I saw a wire harness thru Crutchfield. That's where I am going to Purchase mine. Of course the head unit also. I was told it will keep the bells and chimes. I will go with the install card and have the installer promise to keep the chimes and bells, or back to Crutchfield it goes. they already said they will refund all my money. They have always kept their word on refunds.
The pink wire is ignition...not ACC. To get ACC you need to go to the steering column and get the brown wire. just an FYI.
catching ignition is much better than catching the fuse tap.
Cructhfield has a wiring harness. Its, Pac C2R Gm11. I ordered it today Suppose to keep all chiimes and bells. If you use this code it will save you $20: P74a5-1qudu-74t08. I also ordered a head unit and powered sub woofer......
Chellesimm
Mar 29, 2014 06:12 PM
