Aftermarket sub-woofer popping with power off
Old Jan 6, 2009 | 07:39 AM
garagebuilt's Avatar
anyone use any wire other than the pink one? also where did you tie into it? at the amp in the back?
Old Jan 6, 2009 | 10:05 AM
tahenke's Avatar
I used the Pink wire.
Old Jan 6, 2009 | 12:25 PM
PDW23's Avatar
It did turn out to be the ground. I noticed, as tahenke mentioned previously, that is was the amp powering up briefly every time I would open a door, turn key to accessory, etc. that was causing the sub to pop. I finally moved the ground to some clean metal (under the cargo tie down hooks in the back) which corrected the issue immediately. Amazing how that works !!!
Old Jan 7, 2009 | 07:42 AM
i guess i will redo my ground too
Old Mar 8, 2014 | 09:19 PM
poppagroove's Avatar
Question sub hum
A week or so ago I installed a complete new audio system in my 09 HHR starting with a new head unit,speakers in all the door and a nice little sub in the back... well not so little,Ha,ha anyway, I've got the same pop that was mentioned in other comments but I also have a low end hum when you power up the system...driving me nuts! I'm gonna change my ground tomorrow and see if that fixes it...wonder if it has anything to do with the capacitor I'm using??? hummm any ideas????
Joepoppa1
Jul 26, 2012 08:54 PM
1957John
Mar 24, 2011 09:49 PM
PBnf
Feb 18, 2009 02:16 PM
c2vette
Mar 23, 2008 09:07 PM
rewcolee1
Mar 30, 2007 05:56 PM
